Hm, I just finished rebuilding an LT1. Without going into specific details, I:
- bought oversized pistons, oversized rings, undersized rod and main bearings (used an Enginetech kit from RockAuto),
- took apart the block and heads, dropped them off with the kit at my machine shop. Told them to magnaflux to check for cracks, and if good then hot-tank (clean), then bore the block according to the kit's piston/ring sizes; machine and balance the crank to work with the rod bearings and main bearings I got (also got new Mahle rods). Oh, and deck the block and heads to make them flat (engine blew head gaskets)
- followed the applicable procedures laid out in the Mavrigian book for LT1's (but I've done this a lot so I have the LT1 almost memorized)
- dropped the engine in and followed first-startup procedures.
I would buy cheap rebuild kits from RockAuto. They'll come with the seals/gaskets you need. Do a teardown inspection first because you might stuff that needs replacing that won't be in a rebuild kit, like connecting rods.
I know this is rather vague, but there's different stuff to do for different engines. I don't use Haynes or Chilton manuals myself (I've flipped through them and they're good for one thing in my garage. Mopping up oil spills) but I think they have basic/generic rebuild instructions. I have to do a Northstar soon and it has some very specific and weird stuff, like the oil pump that's friction-driven. I still think you should drop in a used engine, there're just so many of these around.
If you do it, you have to do it right with all the machining, etc. Not like the myriad idiots around me who "rebuild" Honda engines for their ricemobiles thinking that they can just buy internal engine components and swap them out, only to have the engine blow up or throw a rod through the block 5k miles later. HTH
- Don't mix and match, bag and number EVERYTHING. Wherever you took it off, it goes back there: rod caps, main bearing caps, camshaft bearing caps, valve shims, whatever.
- Also, there are some things you don't reuse: gaskets, rod bolts (I've seen it done, but I always replace with the ARP option if available), etc. Go look it up
- http://www.hotrod.com/articles/ccrp-0711-cheap-engine-rebuild/
- at least check a junkyard engine for potential rod knock. Take the pan off, remove the balance shafts and wiggle the rod caps to check for play. Oh and check for silvery slivers in the oil.
Oh, and if you're really set on doing this PM me, I have the Toyota inspection procedures and reassembly instructions. Not nearly as nice as you would think, they want to use special tools for everything.
