1 - 1 of 1 Posts
For all the iPod/iPhone users, today I’d like to share three software which will make your digital life much cooler and easier!
Tipard iPod Transfer Pro, Tipard iPhone Transfer, Tipard iPhone Ringtone Maker, they are all the professional software designed for the iPod/iPhone users. The following guides will respectively introduce their functions in details!
Part 1: How to transfer video to iPod/iPod to PC/iPod to iPod
Preparation:Install and run Tipard iPod Transfer Pro
Step 1: connect your iPod/iPhone to your computer via USB cable
Step 2: According your needs to select the the functions
If you want to import video/audio files to your iPod, click
If you want to transfer iPod files to PC, click
If you want to transfer iPod to iPod, click
Step 3: After you have finished the above two steps,just follow the instructions on it to complete your demands.
Tipard iPod Transfer Pro is the leading iPod Transfer application, it not only can help you:
1. easily transfer audio and videos to iPod,
2. transfer music/videos from one iPod to another iPod.
3. transfer iPod music/videos to computer,
4. transfer photos from iPod to computer;
but also can help you to edit the videos/audio,through the functions of trim, crop, effect, merge files into one,rename,ect.
So we can say, with it you can fully enjoy your iPod without other support!
Part 2:How to transfer video to iPhone/iPhone to PC/iPhone to iPhone
Preparation:Install and run Tipard iPhone Transfer
If you want to import video/audio files to your iPhone, click
If you want to transfer iPhone files to PC, click
If you want to transfer iPhone to iPhone,click
Well, Tipard iPhone Transfer as an ideal iPhone Transfer , it helps you:
1. backup iPhone music and videos to computer,
2. transfer files from PC to iPhone
3. and copy files from iPhone to iPhone easily.
Part 3:How to make your own iphone ringtone
Preparation: Download and install Tipard iPhone Ringtone Maker
Step 1: Click “Browse…” button on the right side of "Input File" to import the file(audio or video file) that you want to make ringtone from it.
Step 2: Click
button to listen the music to find the segment that you want to use it as ringtone.
Then drag and click the start & end slider to set your wanted segment, or type the start & end time in the corresponding text box directly to get the exact segment. Click
to pre-listen the converted audio before generate.
Step 3: Click “Browse…” button on the right side of "Local Output Folder" to choose the output destination.
Step 4: Check "Export to iPhone" option, the converted ringtone will be load to your iPhone directly.
Step 5: After all the settings are finished, click “Generate” button to begin making your own iPhone ringtone.
Just try now, they will not let you down!
1 - 1 of 1 Posts
