2012-2014 Camry I-4's may suffer a shudder in the TC lockup clutch if the transmission fluid becomes too old and/or too thin.
This is basically a design defect, but can be prevented (even cured) by using a relatively thick/heavy WS-rated fluid such as (especially) Castrol Transmax ATF/CVT Universal.
I don't know if there's a shortage (or just because theft is messing with Walmart's inventory control), but I've had trouble finding it at Walmart lately even when multiple store locations showed as having it in stock. It's up to about $25/gallon, still cheap for a full-synthetic.
The transmission holds 7 quarts, and it takes well more than that to chase out 90% of the old fluid. Buy at least two gallons, ...then run ~2 quarts out of the cooler line after over-filling it by 1-2 quarts, ...then repeat.
Please know what you are doing when performing the fluid change and final fluid level checking, ...especially the first time doing this.
Recommend skipping all beer until after you've totally completed the task.
Simply drain and refill the radiator with Toyota pink pre-mixed fluid or equivalent Asian Pink coolant.
I used about 1.5 gallons iir.
Your vintage of Camry's power steering might be electric (perhaps no fluid required?).
The recommended steering fluid for earlier Camry's is Dexron (which is covered by the Transmax application list).
The transmission fluid filter is replaceable, but seems designed never to clog. It's like a super-fine strainer. Dropping the pan can get more fluid and sediment out, while allowing the installation of Toyota-recommended additional two special magnets to the inside of the pan.
Use OEM plugs, gap on the narrow side of spec if adjustable.
A narrower plug gap tends to extend the life of the costly OEM coils-on-plugs.
Coil/plug wires are strictly low-voltage so do not ever need replacement.
Do not use the now-common 40k-mile Fram air filters. These are tested to show poor filtering efficiency (larger holes) than just about all other filters, and I guess why they can keep on flowing air for 40k miles(?).
ProjectFarm on Youtube has tested air filters, check it out (and then buy the good ones online I guess).
The 20k-mile Fram Ultra Synthetic oil filters seem to be well thought of, but I use inexpensive OEM Toyota oil filters and change oil every <5k miles but filter every <10k miles.
Note that only super-cold climates tend to challenge an oil filter's flow rate as the filter ages.
Do not heavily tighten the plastic oil filter housing or they become very hard to remove. I use little torque (10 Ft-lbs) and they never loosen or leak. A special tool is needed, and often a 1/2" breaker-bar and socket to loosen the first time.
I don't super-tighten the drain plug or even use a plug gasket. Never a hint of leakage so far.
I've never looked into these car's fuel filter topics, mine's now 7+ years old but only 32k miles on her.
