1 - 20 of 5079 Posts
must.resist.modding
'09 Camry SE V6
** THIS IS STILL A WORK IN PROCESS. I AM AWAITING ADDITIONAL INFORMATION AS I AM NOT KNOWLEDGEABLE WITH WITH TIRES. IF YOU WOULD LIKE TO HELP FILL OUT INFO ABOUT TIRES (SEE 225/50/18 FOR EXAMPLE), PM ME **
** FOR RESPECT TO OTHERS, PLEASE KEEP THIS ON TOPIC. THIS KEEPS IT LESS CLUTTERED!!! **
OK, there are WAYYYY too many threads of people asking "will this fit?". So here is your ONE STOP source about tire, rim sizes and if there are rubbing issues. Got a question whether or not it will fit, check HERE before you ask in THIS thread! Again, please keep this on topic. ** MODS: please delete any posts that you see that do not pertain to this thread
This thread will be updated more and more as people contribute to this. So check back if you have questions about wheels.
__________________________________________________​
Basic Info:
- How to read a tire: http://www.goodyeartires.com/kyt/readingATire/
- Wheel/Tire size calculator/comparer: http://www.wheelsmaster.com/rt_specs.jsp
- How to measure tire thread depth with coins: http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=51
Example: 215/65/15
  • "215" is the width of the tire measured in millimeters from sidewall to sidewall. This tire width is 215 millimeters.
  • "65" is the ratio of the height of the tire's cross-section to its width. On our example, 65 means that the height is equal to 65% of the tire's width.
  • "15" is the width of the wheel from one end to the other. The diameter of this wheel is 15 inches.
- Stock Offset:+45mm
- Stock Bolt Pattern: 5x114.3 (5 on 4.5")
- Will it throw off my speedometer?
circumference = pi*d
circumference = pi*(wheel diameter in inches*0.0254+2*tire width in mm*aspect ratio/100000)
circumference = pi*(16*0.0254+2*205*50/100000)
circumference = 1.921 m
Then work out the new circumference, divide old by new, multiply by 100 and that is your actual speed at the indicated speed of 100km/h (then convert to imperial, since I'm not sure if the formula works in feet/miles)
- Wheel and tire calculator- To also help us understand offset, here is a simple diagram (courtesy of moky-tron)
- Hubrings
What is hubrings and what does it accomplish?
60.1 is the inner diameter (Toyota/Lexus hub bore all have 60.1)
73.1 is the outter diameter (In this case, your wheels have center bore of 73.1)
The hub centric rings primary job is to fill the gap between your aftermarket wheels and the car's wheel hub bore. 73.1 - 60.1 = 13.0 mm is the gap.
Why such gap? Because each vehicle manufacture wheel hub bore are difference, hence all Toyota/Lexus wheels are 60.1 mm so it will match the car hub bore exactly. Aftermarket wheels wants to sell their wheels to a wide market of car makers so they make a universal hub bore to fit as many vehicle as possible. That is why you need a hub centric rings. (courtesy of wetherburner/lammydi)
- What are some recommended spacers and what do they do? H&R or Ichiba (www.ichibausa.com). Spacers reduce the positive offset, i.e. push your rims further out to the fender. Putting a 10mm spacer in the back on a +40mm offset, makes the offset effectively +30mm. (courtesy of tobeit)
- When are lug extenders needed? If it is 5mm or less spacers then you can safely use the OEM hub studs. But any spacers that is longer I would replace the OEM studs with extended studs. Safety first. (courtesy of lammydi)
Tires
215/60/16 - STOCK GEN6 STEELIES
225/60/16 -
235/55/16 -
215/55/17 - STOCK GEN6
225/50/17 -
225/55/17 -
235/50/17 -
225/45/18 - STOCK GEN6 TRD (10 spoke)
225/50/18 - will give you more comfort (bigger sidewall) and will shorten the wheel gap (bigger overall diameter) BUT it will make your rims appear smaller.
235/45/18 - closest to stock overall diameter of stock 17"
235/55/18 -
215/35/19 -
215/40/19 -
225/35/19 -
225/40/19 -
235/35/19 -
235/40/19 -
245/35/19 -
245/40/19 -
215/35/20 -
245/35/20 -
245/40/20 -
Offset
Stock = +45mm
7" Wide Wheels
TO COME
7.5" Wide Wheels
TO COME
8 or 8.5" Width Wheels
+35 to +45 for the flush look - rubbing may occur if you are lowered, and may result in having to roll the fender. Also depends on your tire size.
+45 to +48 isn't recommended for a rim width higher than 8, it will result in rubbing and/or hitting the strut
NOTE: ALL QUESTIONS/COMMENTS ABOUT "AGGRESSIVE" (HELLAFLUSH) WHEEL AND TIRE FITMENT, PLEASE SEE Official Aggressive (Hellaflush) Wheel/Tire Fitment: Questions? Click here*. THIS IS STRICTLY FOR REGULAR WHEEL/TIRE FITMENT.
NOTE: PrincessPeach is inactive and hasn't been on here for a while. Post your questions here instead.
I get about 5-10 private messages a week asking me about aggressively stanced wheel fitment. If you have questions about...
1) How to flush/poke your wheels
2) How much stretch can you get away with
3) Rolling and pulling fenders
4) Maxing out stock camber bolts etc
5) What offset/width would be best for an aggressive fitment
6) And so on...
I'm not very arrogant at all, but I am very knowledgeable in this field of "hellaflush" or flush fitment. If you have ANY questions, post your questions here and I'll be more than happy to help you out. Since this is a rare breed and comes with a lot of negativity, I'm hoping those negative comments will be excused in the hopes of less clutter and nonsense in this thread. Only people wondering about aggressive wheel fitment on their Gen 5+6 should chime in. Of course, my knowledge lies within the Gen 6, but I'm hoping Asian and the others with the Gen5 may contribute. I have a host of users here that can attest to my help, and I'm definitely willing to extend this knowledge to you. Ask away!
Online Wheel & Tire Fitment & Stretch, Rolling Radius and Speedometer Error Calculator, compare fitment
http://www.willtheyfit.com/
**Useful tool to help calculate just about everything for your fitment!***
OFFICIAL HELLAFLUSH PICTURE ONLY THREAD
http://www.toyotanation.com/forum/showthread.php?p=3343891#post3343891
SEND YOUR SPECS THROUGH VIA PM TO ME IF YOU WOULD LIKE YOUR RIDE FEATURED IN THE THREAD.
..no im not yelling.
Paul_09WhiteV6
09 XLE V6 White
for those wondering what rims to get:
first decide what size you want. 17s or 18s are for comfort. many people will recommend to atleast go 18s as they will go bigger and you won't really notice a difference in ride comfort from 17s. 20s are for looks. you won't have as much tire and will feel much more things on the road then with other rims. 19s are inbetween but the tires can get pretty expensive. you can go 21s but thats very little tire and it gets expensive.
next decide on the style and finish. there are many finishes out there and you can have rims powdercoated to whatever color you want. if u want chrome but don't want all the problems that can come from it down the line like the finish looking old and sometimes even pealing then go for a mirror cut finish. many people here prefer the 5 spoke styles but you really see the brakes then and the brake dust at times.
last decide what tires you want based on the chart above.
if your really undecided then go to a site like discount tire that will let you put all the rims they offer on your car on their website or go to a local rim place and ask them to put some different rims against your car so you can decide what you want.
if u plan to get rims on the internet then remember you need to factor in shipping(though many places do free shipping now), balancing, mounting, hardware like hub centric rings if it doesn't come with order, and transfering of the tire pressure sensors. all these things can add up and make the purchase more than if you would of had a local rim place get your the rims and put them on.
offset: if u want to skip the diagram and trying to figure it out them heres a quick bit of info:
the offset determines how far or close the rim will be to the fender or struts. for the camry you want to really be within the +35 to +45 range. +35 will mean the rim will be closer to the fender. +45 will be closer to the struts. everyone on here will tell you to look for a +35 offset as long as the tires aren't too wide as it will have that flush look with the fender. by flush we mean how close it is to the top most out part of the wheel well. a +35 offset with a decently wide tire will get you major style points on here but not everyone can do it depending on the tires, width of the rims, and the offset the rims are available with. you can always use some hub centric spacers with studs to get the wheels to be more flush.
2007 Camry SE V6
245/35/19 Definitely fits (as you can see in my sig pic) but the tires look too thin as 245/35. Maybe 245/40s would be better.
By the way, EXCELLENT JOB! I'm fairly tired of seeing all these "will these fit" threads.
Recommendation: You may want to see if you can do some type of grid reference chart thing because some people will want to know if certain size wheels and tires will fit on their lowered cars. Maybe you can have a chart with the tire size, car height, and comments columns? But of course, wheel width is also a potential issue...
SIZE............................STOCK HEIGHT........1" DROP.........2" DROP.............COMMENTS
235/35/19....................OK.........................OK.................OK.....................
245/35/19....................OK.........................OK.................OK.....................
Paul_09WhiteV6
09 XLE V6 White
245/40/19 is perfect. i have some pics of my setup around on here and you'll see they are perfect. i would make the pics out in the open more but punks would be crying about my gap. i'm saving for coils though so riding on stock height right now.
must.resist.modding
'09 Camry SE V6
Discussion Starter · #5 ·
Good idea but too much work and not possible with the way the board is setup. It look clean.
As stated, this is still a work in process. Not all tire sizes are listed and I only took whatever I can from for those who knows about wheels and tires, I have the rims tire size listed. Post any info on the size like..
If it will rub or if its not good if dropped, I will put a disclaimer.
Paul_09WhiteV6
09 XLE V6 White
they aren't that bad redline. but i kind of have to agree. i wouldn't put nissan rims on my car. try to find some GS 5 spoke 18" rims like lammy had. i believe you should be ok but you might need to roll the fenders. specially if your dropped. lammy will know better than me though.
I wanna get the 350z wheels but it comes with those 245-45-18 tires, and idk if they fit
What Gen Camry (5 or 6) are you planning to put the 350z wheels on? I know for sure on a Gen5 18x8+30 with 245/45/18 you will have rubbing issues. If your car is at stock height it isn't bad until you hit a dip or when the road is uneven you will hear the tires rubbing against the fender. To avoid the rubbing go with 225/40/18 or 225/45/18. Your tire will be tucked in the fender. As far as the rear 18x8.5+33 with a rolled or shaved fender you can put 235/40/18 would do it. :thumbsup: Hope this can help.
Ok i would love to get these rims. (no pic of them for now, can't ruin the surprise)
Sizes are
18x8.5 +40 offset 3'' lip
18x9.5 +40 offset 4'' lip
Question is, what tires? I know the lip is outta control but and these are 18s but i am on coilovers and i need a bit more tire. The bolt pattern is 5x114.3 but i have to call and ask about the hub size.
Paul_09WhiteV6
09 XLE V6 White
get 45 no matter what. 50 will be too much. idk if u want more of the lip sticking out or you want a wider tire. if u want wider then do 245/45/18 in front and 275/45/18 in back. if you want more vip/more lip out then 225/45/18 and 245/45/18.
Paul_09WhiteV6
09 XLE V6 White
you can do 50 then. just will make the rims a wee bit smaller. pm me and tell me what your looking for and i'll tell you want tires to get.
Paul_09WhiteV6
09 XLE V6 White
I kinda wanna surprise you to tho lol. I haven't seen anyone with anything similar on a Camry.
haha not with rims. just if your looking for more of the rim lip to be out etc.. i'll help you choose the right tire size instead of cluttering this thread.
Reactions: hawkmanj
I still think that this is a useful discussion to read through for anyone looking to do the same. But right now i'm leaning toward 245/45/18 and 265/45/18 I want just a little bit of stretch and don't want the sidewall to go over the outer lip.
Paul_09WhiteV6
09 XLE V6 White
your right. just don't want to get this locked. i think 245 might be a bit too much sidewall according to what your looking for. i have x8.0 with 245 and as you saw i have lots of sidewall. i doubt you'll have much less with x8.5 rim. maybe 235/45/18 in front then and 255/45/18 in back. you can probably do 50 for both sizes too if you want more tire.
