Redding out tails sanding Q.
865 6
What grit do you use to sand down the paint before clearing coating it?
Thanks. :)
1 - 7 of 7 Posts
That Geeky Star Wars Girl
i would think the higher grit sandpaper like 3000 grit and when you do it i would wet sand gently, should make the clear coat nice & glossy.
good luck,
Keri
Zzzz
Camry
Discussion Starter · #3 ·
Thanks, Keri. My one tail is kind of dark, I'm considering just sanding it all down and starting over.
The other tail is drying right now.
I decided to use the Testors paint, which is so far turning out beautifully.
Zzzz
Camry
Discussion Starter · #4 ·
Update: Tail isn't dark, just the clear-coat went on kind of opaque, but now that it's drying, it cleared up nicely.
I have the other tail in the basement drying it's second coat of paint, then it's time for clearcoat. :)
I think I'm only going to use 2 coats of clear on each.
2 coats of clear is more than enough, you don't want it to turn out too glossy which would look kinda weird.
i've been experimenting with my tails too right now...and i first tried using the krylon stained glass paint in red. after 3 attempts i can safely say that paint is pure crap. it bubbled up & gave a "wavy" texture to the lens every single time and though i sprayed very light, it would come out so red it looked black if you know what i mean.
so i'm going back to my most excellent spraying testors candy apple red and seeing what kind of results i get from that. i guess its a good thing the tail i have been practicing on was an extra that i picked up off ebay for $10 :)
post pics when your finished, looks like you will finish way before me :)
Keri
Zzzz
Camry
Discussion Starter · #6 ·
I'm already done, I'd just like to lightly sand it a bit more. I'll take some pictures tomorrow though. :)
The clearcoat suggests a 24hr drying period to prevent finger-prints. I carefully, so not to touch the painted part (I taped mine off so the black edges wouldn't get sprayed) reinstalled my tails. I figure if anything, outside is cleaner for them than on my basement floor.
Suffice to say, I got a glimpse with a flashlight, and it looks quite good.
Let me know how you make out.
BTW, I did 2 coats of testors and 2 coats of clearcoat.
1 - 7 of 7 Posts
