When programming a remote, if the locks cycle twice at the end, that is the signal that the remote DID NOT program properly. I had this problem and tried 10 times failing each. I then learned that if I repeated the last couple of steps several times, eventually it worked --- and gave the signal of only one cycle of doors locking and unlocking. Said another way, keep repeating the step where you press both lock and unlock buttons "perfectly simultaneously" until you get it right and the door locks cycle ONLY ONCE. Use two hands, not both fingers from the same hand!!! Finally it worked. All repeats might have to be done within the 40 second time window however.
