1 - 6 of 6 Posts
2005 tacoma trd
Ok here is an update on my remote starter model compustar 1w900fm .installed on monday this week. got a check engine lite on tuesday had a free check done at auto zone, the read out was running lean on bank 1&2. took truck back to installers and they changed the tac pick-up lead to the tac wire in the dash. They had it on one of the coils on the spark plugs. There was some leak back on the ground causing the lean condition. tech support from compustar told them to do this. So far everything is a-ok now works great locks are on the remote also work fine. what i like about this one is its upgradeable.you can add more features if you want all the way to there top of the line kit.:thumbup:
· Surfing TN via iPhone
05 Tacoma DC 4x4 TRD
Cool.
I hope they did a good install. Because a good installation is almost more important than the the actual alarm hardware.
If you have any problems, be sure to make them fix or adjust it.
My compustar never false alarms, so don't put up with an alarm that does. It is easy to adjust the sensitivity on the shock sensor.
The remote starter was really nice this morning as I was leaving work. It was about 20 degrees outside, but my truck was all warm and toasty inside. All the guys at work were envious.
:D
2005 tacoma trd
Discussion Starter · #4 ·
299 out the door here in ny the home of high taxes
2005 tacoma trd
Discussion Starter · #6 ·
im shure you can do it i just dont trust myself with that stuff it has to be right theses guys do them for the toy dealer here in town
1 - 6 of 6 Posts
