1 - 3 of 3 Posts
Toy-Cel
I want to take out my whole ac system
1. cause it doesnt work anyway
2. to free up a little more power
Has anyone here done this and can give some tips? hoe tows?
what all needs to be taken out?
Compressor, belt, various hose lines.......?
Trailer Trash Engineer
Have a shop pump out the freon, then just remove everything related to the a/c. Compressor, hoses, brackets. You'll probably have to get a shorter belt to replace the one you take out. The evaporator coil is in the heater box under the dash and would probably be a pain in the butt to remove, so just take out the hoses to the firewall. Your biggest gain will be the weight loss. The pulley uses nothing unless the a/c is actually on.
Resident asshole
Corolla
Why do you want to take it out?
When its turned off theres no power loss anyhow, cuz the magnetic clutch is disengaged. If thats the reason.
1 - 3 of 3 Posts
