I have removed the radio in my tC, and I would assume that the mounting is the same in your car. All you have to do is remove the trim piece on your dash around the radio. After that, there are 4 bolts that hold in the factory radio. Should be two nuts on studs at the top and then 2 screws in the lower area of the deck. I am not sure if they are the same, but since the decks fit in each car, I would assume that they are very similar.
