1 - 12 of 12 Posts
on my 96 camry, the white/red stripes on the sides of the car are completly, worn down, and actually make the car look uglier than it already is right now... how do i remove this without scratching the paint?
I removed rubber edgings on my brothers gen4 camry in between the door panels, and part of the vynl fell appart, but used a sharp knife, and cut it back to size without scratching the paint.... thats what experince i have with this sorta thing right now.
try waiting until it's hot out in the sun and park your car and let them soften up. use a credit card to get an edge up and peel away. You can also try some goo gone or another adhesive remover.
you can use a hairdryer (preferably a heat gun) to loosen it up then just pick at it with your fingernail until you get a hold of it. The just pull as you loosen it with the heat from the dryer/gun. Use tar and bug remover to get rid of anything thats left.
Camry
Just be aware the paint color under those stripes may not be the same as the rest of the car. Fading and discoloration on exposed surfaces. :eek:
Know God. Work Hard.
4Runner
And ALSO be aware that some of those goo-removers will strip your paint!
Discussion Starter · #6 ·
ummm... i should take a picture of what it looks like, but its 50 degrees outside and raining :( .... but theres no constant vynle peice, its all WORN down, stripped,cracking, the whole 9 yards.
G
This seems to be the general consensus from past discussions.
Yay, I used big words! :D
Camry
I remember a topic about removing Toyota badges/emblems glue where there was a scraper (putty knife?) that could work with a heat gun.
It's in here somewhere. Do a search on removing badges. I used WD40 (let it soak in a while) , fingernails and cussing.
1 - 12 of 12 Posts
