1 - 5 of 5 Posts
AE92 3SGTE
'90 Coroola 3SGTE
Whats the process for taking off a clutch master cylinder on AE92's? Pretty easy? Thinking of going to pick and pull tomorrow to grab one.
iAzn
1988 toyo Corolla DX
It's easy... The two bolts that holds it is where the pedal mounts up inside the car. Then you just take the clip out that's for the plunger. Then it should easy maneuver out under the hood.
The hardest part is the cramped working conditions under the AE92 dash, I changed mine when I put my new clutch in here recently and it wasn't too bad.
This may be a problem unique to the coupe but how do you get the line off the clutch master cyl? Can't seem to get to it even with a folding line wrench.
Ok so for future reference you have to unbolt the brake booster and pull it away from the firewall as part of the clutch master resides behind it.
And the only way I was able to bet the bard line off was using a pair of vise grips.
1 - 5 of 5 Posts
