Removing Front Emblem
10370 Views 12 Replies 7 Participants Last post by  Glenn8963
Ive searched all the tips and tricks on the forum but none of them seem to be working for me. Ive tried using a screwdriver to pry it out but it doesnt seem to budge. Its a 2011 Camry LE . Any Help out there?
1 - 13 of 13 Posts
If you look on the inside of the bumper, there's little white plastic clips that you can just use the screwdriver to push towards the center of the emblem. there's 5 or 6 i think. and the whole emblem along with the little mesh backing should pop out with it.
Try sticking a screw driver inbetween the emblem and the part thats behind it. then gently try to wiggle it out and push so the clips let it out. it was easy for me and i didn't scratch the car at all.
how does one go about putting it back in? what's the best adhesive to use?
^ putting it back in is easy it just pops right back in
its kidna hard getting behind the emblem due to stuff under the hood blocking the way.
i could just take whole grill off but im trying to keep it simple.
my smallest drive wont fit b/w the chrome and the mesh :/
well, I never tried removing my front emblem, but it's quite loose...I can put my finger on it and jiggle it so it seems it might fall off
one can always go to pep boys and buy the 3m tape, usually located in the body repair isle. comes in all sizes and thicknesses...........
are u trying to remove the entire emblem itself from the bumper or are u trying to remove the emblem from its backing?
thanks "njerald" jr.. I was messin with it earlier and I understand how it pops in now...still jiggles around though so I think I'll try some tape then...
since you said it was loose, i was actually trying to help you suggesting the 3M tape to hold it down..........I WAS not being sarcastic in any way.........
so for you i will say this...........
GO FOOK OFF NOW............
im trying to remove the whole thing. then remove it from the backing.
if theres a trick just for the emblem im all ears.
ive tried removing both neither really wants to come off :/
but yeah its loose when u first get it.
not entirely loose but it jiggles alittle
Simply amazing..................
isn't it though.......??
they think we are related..............
never knew i had a kid brother...
we must have been separated at birth........:naughty:
1 - 13 of 13 Posts
