1 - 1 of 1 Posts
First off, I am NOT a mechanic and was learning as I was going here so I'm sure there are better methods for doing this but I had little luck finding solid information online - so I'm posting this in the hopes it will help others in a similar predicament.
I have a 2003 Toyota Highlander with 3.0L V6.
My "check engine" light was on and after plugging in a code reader discovered 2 codes:
P0155 - Code for Bank 2 sensor 1 oxygen sensor (front of engine going into exhaust manifold)
P0135 Code for Bank 1 Sensor 1 oxygen sensor (rear of engine going into exhaust manifold)
Both of these sensors are between the manifold & catalytic converter, and are therefore known as "upstream." They are identical part #'s - Denso #234-9009.
See attached .pdf for step-by-step instructions with photos.
1 - 1 of 1 Posts
