Have you removed the cylinder heads yet?
Generally speaking, you first remove the cylinder heads, then you remove the lower half of each connecting rod, and then push the pistons out through the top of the block. You want to keep all the connecting rod halves together, so that you can reassemble them the same way.
After you have removed all the connecting rods and the pistons, you then remove the main crank bearings, which frees up the crankshaft.
One minor detail is to put a short length of rubber tubing over each connecting rod bolt, as you are removing it from the crankshaft throw, in order to keep the rod throw from being scratched. Apparently, marring or damaging the smooth rod throw surface could make a difference in the oil distribution.
Can you provide a little better picture next time... maybe a little more light to see what you are doing. ... thanks. ... Do you have a service manual to use as a reference? There are probably a few details that you would want to check up on. You can download a service manual if you don't have one. The link is
http://www.techinfo.toyota.com/
