idk if the oil pump and balance assemblies have to come off first however it does have some badass silicone holding it on
I've removed these with the balance shafts in place so they can stay.idk if the oil pump and balance assemblies have to come off first however it does have some badass silicone holding it on
I removed the balance shafts and oil pump.thanksidk if the oil pump and balance assemblies have to come off first however it does have some badass silicone holding it on
Yes I have the bell housing bolts plus the axle shaft bracket bolts. I should have pulled it but watched a you tube that said you could do it with the engine in it and it wasn’t hard. Guess what, he was wrong. Left out a bunch of things. I guess it is just stuck and I can’t get to it to break it loose. Thanks for your help.I've removed these with the balance shafts in place so they can stay.
@Covah161 I presume you got the bell housing side bolts as well? Also there is a axle bracket on the back but forget if it's attached to the upper or lower block. If it were me I'd pull the engine if you have the resources. It will be much easier to remove, inspect, and repair anything that is needed. Well worth the efforts in my mind (and my old back thanks me).
After taking the oil filter off is there anything in the oil filter housing that has to come offYes I have the bell housing bolts plus the axle shaft bracket bolts. I should have pulled it but watched a you tube that said you could do it with the engine in it and it wasn’t hard. Guess what, he was wrong. Left out a bunch of things. I guess it is just stuck and I can’t get to it to break it loose. Thanks for your help.
