OMG, First off, why are you replacing everything. 2nd, Not cheap in anyway. If it's because the compressor came apart and contaminated the system i would replace the compressor ( Toyota now offers a complete reman for a good price) and the receiver/dryer and back flush the rest of the system once you remove the lines and sepperate each part of the system then recharge and retro fit with R134 service ports and it should work just fine.I normaly retro fit these when i do any a/c on these older R12 systems with zero problems.
Years ago Toyota had a service bulliten that stated that the entire system needed to be replaced to convert to R134 and was complete nonsence. Will the old system (rubber lines and seals)leak out some R134 over time? Yes 3-5 years has been my expeareance.
