Not sure what is going on here, I went over everything and don't see anything wrong. It seems to make plenty of power but over 7k rpm's it just sounds... off. I can hear lift kick in at 6k but after 7k rpm it almost sounds like it's just winding. Computer isn't detecting any misfire... I'm not really sure what I could've done wrong...
best i can describe it as a buzzing sound. I don't see any oil leaking from around the gasket. I made a video but not sure if it really comes across. its most noticable after like 7500rpm
i used a fel pro gasket kit. I will say I had some issues installing teh spark plug gaskets, i only ended up replacing one of them because I broke the first one I tried to install, so I figured I'd just leave the other 3 since they seemed fine anyways. I obviously discarded the broken gasket and used another new one. I used the black RTV on the 2 little divets near the timing chain cover like it says to do.
