Last weekend I replaced the brake fluid in my 2013 Avalon HV Limited. The procedure is somewhat different than any other car or truck I have done prior.
I'll give a brief description assuming you have done brake fluid changes before. For a more complete step by step go to Toyota TIS. Here you can purchase for $20 a 2 days access for legit Toyota FSM pages. You can't download a complete manual for which I understand.
To change brake fluid.
1 Remove all 4 wheels.
2 Place braking system in in-valid mode by the following procedure:
Turn on car (Not Acc) with parking brake engaged.
Move shift lever to N and the press brake pedal 8 times in 5 seconds.
Move shift lever to P and the press brake pedal 8 times in 5 seconds.
Move shift lever to N again and the press brake pedal 8 times in 5 seconds.
Move shift lever to P.
You can verify invalid mode when the yellow brake warning light flashes quickly. Be careful not to let the hubs turn during the fluid change. It's one of many things that will kick the system out of invalid mode.
3 Use something to suck as much fluid out of the tank.
4 Start at the right front wheel and pump the fluid out doing the standard procedure. (Press brake pedal, open brake bleed plug till pedal hits floor board, tighten plug, release brake pedal, repeat till clean fluid is discharged)
5 On left front wheel repeat step 4
6 Next bleed left rear wheel. Here is were things differ. Press the brake pedal and loosen brake plug. Brake fluid will start pumping out quickly. (I found the 5 seconds was plenty of time). Tighten plug and release brake pedal.
7 Bleed right rear wheel using step 6.
8 All done. Just be sure to check the fluid level in the tank often. If you start sucking air from an empty tank this will take awhile to clear the air out.
Good luck.
(edit note. Original post had steps 4 & 5 side of car reversed)
Good luck.
