1 - 1 of 1 Posts
All right ; here it is from hard experience::headbang:
If you have a 1992 or a '93 you probably have replaceable front struts. You can tell it if there is a round wide disc near the lower mid point on the strut. That's Toyota's OE, and in that disc is a bearing. If you want OE struts, Toyota tells me that these struts are on National Back Order (3/21/09). If you want to go cheap, and not hassle with making more work for yourself, go get the Monroe struts from Pep Boys or NAPA; these fit.
But you may want to go to sealed struts. If you do; heed this:
You need to swap out the top strut mounts and get a strut bearing and other new parts you may not have seen on you '92 or '93. See here:
http://www.toyotanation.com/forum/showthread.php?t=264092&highlight=strut+bearing
You have to get the '95 parts to make this happen. Without these you cannot make the struts safe. Read that entire discussion; it'll explain everything.
Remember: if you want to go to sealed struts, you MUST do this!
Tedders
Drive Laughing!!:lol:
1 - 1 of 1 Posts
