1 - 8 of 8 Posts
I need to replace my starter and I was wondering if I can do it without disconnecting the battery?
No, and you'd be insane to try (which is intended as a warning to one and all, not just you).
2015 4 Runner SR5
If the concern is losing memory related things in the radio, etc. you may consider buying a memory saver/keeper kind of thing. Generally speaking you disconnect the battery (negative terminal is fine) for anything that involves a power wire.
And in the case of a starter it's the biggest power wire in your car. I dread to think what would happen were a dead short to occur on live starter motor wires, even with a fuse involved.
I've done many a "tiny job" without disconnecting the battery. But I would never think to deal with a starter replacement unless the battery were disconnected first.
2015 4 Runner SR5
I think I read a case where someone was replacing the stater and either left the battery connected or wound up shorting the battery and had all kinds of issues with the ECU. I agree 100% - disconnect the battery when working on the starter FO SHO.
2004Toyota Camry V6
If you try and remove starter without removing the battery ground cable, I guarantee you will never do it again. Word to the wise. The starter battery connection is HOT.
2004 Toyota Camry, 2017 Toyota Camry, and many many more lol
Don’t do it I have seen people forget to do it sometimes it doesn’t work out too good in the end
1 - 8 of 8 Posts
