Does any one know what steps I should take and what is needed to replace the rubber that goes around the lining of the trunk. I would like to replace mines since is practically coming loose.
You mean the seal. The seal slides down over a chassis seam. Gently atempt to pull the seal up, you should find one area that is loose enough to pull up. Then move along the seal the pull the rest up.
do they sell these over at autozone or advance my trunk gets water in it and im thinking is because the weather stripping in the trunk is loose maybe I should replace it. just don't know if I need a new one or just reseal the old one.
1 - 3 of 3 Posts
