Since there doesn't appear to be a DIY on replacing the water pump on a 9th Gen Corolla. I was wondering if anyone has replaced their water pump themselves, how difficult it was, and where they purchased the pump and fluid?
Have a 2005 Corolla LE with only 63,000 miles on it that both the Toyota Dealership and a local brake/muffler shop have indicated the water pump is leaking (possibly from the water pump weep hole). Toyota Dealership wants $580 to replace the water pump and coolant (no flush, just drain). Local brake/muffler shop wants approx. $300 to replace pump and fluids (again no flush, just drain). Local Toyota Dealership parts department sells the water pump for $121.50 and a gallon of fluid for $23.99.
I've been looking through old posts including this one and this one and a few others on this site. And this DIY posted on some guy's website. And reviewing the following two Youtube video's trying to determine if it makes sense for me to replace a possibly leaking water pump or paying $300 or more for a local shop to replace the pump.
Some questions I'm trying to get answers too before deciding on doing it myself:
- What water pump brand are people using, where was it purchased from, and for how much?
- Did you do a coolant drain then flush, or just a coolant drain?
- Did you use the radiator petcock to drain the radiator or pull a radiator hose to drain?
- What coolant fluid and which type did you use? Toyota SLLC type, Zerex Asian, or other?
- How much coolant is needed? More than 1 gallon?
- What procedure did you use? Slip off serpentine belt from alternator/water pump, drain coolant, pull alternator, pull pump and reverse the process?
- Is a torque wrench needed? If so; where is a good place to buy an inexpensive torque wrench, and to what torque should the bolts be set to?
- What other tools or products would be needed to replace water pump?
- Anything to look out for, recommendations, tricks or techniques to make doing it yourself easier?
