1 - 2 of 2 Posts
upnorth previa
96 Previa
My previa has a leak on the passenger side window, any ideas on an easy fix / replacing the window stripping?
1991 Previa 5 speed,
Need more info .... Which passenger window? Where is it leaking? Are you sure it is not leaking where the front roof rack holes are drilled into the roof and running down the door? Is the rubber stripping damaged or missing, or how about the door rubber? If it is a rear window, could one of the hinge bolts be loose? ( Common problem). ... There could be lots of answers to your question , but more info is needed
1 - 2 of 2 Posts
