how do i reset the ECU
P phishmale · Registered Joined Mar 9, 2004 · 26 Posts Discussion Starter • #1 • Oct 17, 2004 how do i reset the ECU
B BDSL · Registered Joined May 6, 2003 · 280 Posts #2 • Oct 17, 2004 Remove the EFI fuse for 15 seconds and plug it back in.
P phishmale · Registered Joined Mar 9, 2004 · 26 Posts Discussion Starter • #3 • Oct 18, 2004 i also heard if your disconnect the battery it resets it is this true also?
9 91MR2quickNA · Registered Joined Jul 1, 2004 · 1,353 Posts #4 • Oct 18, 2004 You can undo the neg. terminal on the battery for about about 1-2 minutes and also the ECU-B fuse.
P patR1 · Registered Joined May 2, 2005 · 52 Posts #5 • Jun 6, 2005 i have a kill switch which disconnects the ecu fuse..... is this ok if my ecu is resetted every single time???
