1 - 13 of 13 Posts
New 2006 Corolla LE owner
hey all I drive a 2006 corolla LE automatic. I usually just rev to 4500 rpm. But how often can I rev to 5 or so without causing damage? I have hit over 5 a few times. Just wondering if its bad to do a lot. I know this is a corolla, not a Neon and it can take a lot of abuse, just dont want to abuse my car too much.
2005 Corolla XRS
I rev my car to 8200rpms a few times a week, I think it's probably good for the motor to work it out a little bit.
long as your not bouncing off the rev limiter on a daily basis its not going to hurt it too bad. generally 4500 is about normal i would think, just keep in mind the harder you drive it the faster it will wear out. but on the flip side driving it like a granny will wear it out too just in different ways ie. carbon buildup and deposits. theres a comfortable medium and it sounds like your there..
yeah, even my old 1989 corolla automatic revs to 6500 on every shift if I floor it, and it sounds pretty happy doing it. That has a lot to do with how well ballanced a motor's crank shaft is, and toyota seems to have done a pretty good job of that
Vroom?
2003 Audi A4
drive it as you like. As long as you do it regularly it should be ok. like they said, just don't rev it insanely high all the time.
Thats what can make used cars so bad, usually the difference in how the different owner drives it tends to wear things out faster since they are not used to running that way.
1 - 13 of 13 Posts
