very interesting, thanks for the info
MIL = Malfunction Indicator Lamp <<<---- e.g. idiot light or some call it the "check engine light"tagpats said:for those of us who are not mechanics, would someone mind explaining in layman's terms what this means?
"...may exhibit a M.I.L. “ON” condition with DTC P2716..."
thanks, very helpful! appreciate the feedback.onsknht said:MIL = Malfunction Indicator Lamp <<<---- e.g. idiot light or some call it the "check engine light"
DTC = Diagnostic Code
Basically what happens is the idiot light goes on and the TCM in this case stores a malfunction code... As referenced in the actual DTC, for some reason I ran into the next one 2757 in my previous post.
"When an open or short in the linear solenoid valve (SLT) circuit is detected, the TCM interprets this as a fault. The TCM will turn on the MIL and store the DTC."
Basically what you need to do is get the U660E factory service manual and lookup DTC P2716, I just do a ctrl + F and then type in 2716 before I hit enter.
