1 - 2 of 2 Posts
W
Hi,
I am wondering how difficult to remove factory installed speakers(front
door) from my 2000 Corolla. In the instruction from crutchfield.com, I
need to drill off the rivets. Here are my questions:
1. Do I need a bit for drilling the metal or aluminum? do I drill
through the center of the rivets?
2. After removing the rivets, do screws coming with the new speakers
will fit the original holes? I like to put back the factory speakers
someday before I sell my Corolla, could I use the similar screws to
screw the speakers back om?
thx
R
Guest
Discussion Starter #2
<[email protected]> wrote in message
news:[email protected]
> Hi,
You will need a drill bit that is designed for drilling metal. Unless the
bit has an unusual point or is marked as a wood boring bit, it should be
able to handle drilling out a rivet. Rivets are pretty soft metal and
should not take long to drill out.
Use a bit with a diameter that is slightly larger than the hole that the
rivet is instlled through. You are basically trying to remove the metal
where the shoulder (mushroom cap) meets the shank of the rivet.
> thx
Whether the screws that come with the new speakers will fit in the original
holes depends on the size of the screws. If the screw is not the right
size, you can purchase sheet metal screws at any hardware store.
Ray O
1 - 2 of 2 Posts
