True.. but those speed cameras are computers with whatever accuracy (rounding) coded into it...
When did the topic change from in car speedometers to radar speed cameras?
If you want a 100% accurate in car speed reporting device it will have to be radar/sonar based that measures the elapsed time to traverse a given distance - it can't be any currently used technology in that they are all dependent, in one way or another, on vehicle components (tires specifically) that are by their very nature analogue. It most likely would have to be radar based since radar operates at the speed of light (186,000 miles per second) versus sonar which operates at the speed of sound (
about 767 mph depending on air temperature, humidity and density) making radar orders of magnitude more accurate.
It can't be GPS based for a couple of reasons:
1 - GPS is by it's very nature delayed. Most commercially available GPS devices update the location at 1 second intervals so best case is it would report the speed you were traveling recently versus currently.
2 - GPS is only accurate within its' capabilities for a vehicle traveling on a level surface - if on an incline or decline the distance traveled on the surface of the road will differ from the linear distance traveled across the surface of the planet which is what GPS will measure.
...Picky I know.. but the signs should be changed with "≤" (less than or equal to).
Well, if we're really going to get picky then the signs will have to stay as they are since the
limit is an absolute, not an 'about'.
In your suggested ≤50 MPH 50 is still
the upper limit. You could kind of get around that by changing the signs to ~50 MPH (~ being 'about' or 'approximately') but now you have an enforcement issue in what constitutes 'about' (lawyers would love it though). Is it 3 MPH?... 5 MPH?, etc. Even if that last issue could be resolved the 'system' still fails because at some point the same problem exists with xx.99...999 versus xx.00.....001 when it comes to measuring the upper limit.
Bottom line - it ain't perfect, but it's the best we got.
