21 - 40 of 54 Posts
FBJXR
'05 X-Runner
theflavor said:
If you had the rail cross bar you could mount two bike mounts on it near the end of the bed and have 4 bikes together. Two facing forward, two facing backwards. If you had them all facing the same direction the handlebars would probably all get in the way of each other.
if you use single mounts on each long side of the bed you could fit around 6 bikes in the bed. i have fit 4 but i am sure you could fit atleast six plus gear
Only 48 more payments.
2005 Toyota Tacoma
vendeta2k said:
Here's a couple updated pics with the washers installed......
Good idea, I think I'll do that for some added insurance. Not that my bike has popped out of the track, but why find out. :thumbup:
Paseo/Tacoma
vendeta2k said:
mine were keyed the same.....not sure if that was intentional or lucky......
Thanks for the quick reply, I almost bought new cores!
My bike mounts arrived today, much sooner than I expected! I'm very impressed with the quality, these mounts are built to last.
The hardware store was closed by the time I got home from work, so I still need to pick up the washers (a needed addition, I can see why it is recommened).
Thanks for the advice!
2005 Toyota Tacoma
Nice I can't wait till next week when I pick up my new bike and get my other one back from being repaired. I'll have to snap a pic of the mounts in action. :clap:
Paseo/Tacoma
My mounts should be here tomorrow, UPS says they are only a few miles away :)
Toy Machine
vendeta2k said:
Another "mod" that I added to my Rocky Mounts was swapping the socket heads bolts for "button head" allen bolts.
The rounded head makes it more difficult for someone to simply remove the mounts with a pair of pliers.
I've also thought about using Torx head bolts, as it's even less likely that someone would have a Torx driver handy when they thought about snagging the Rocky Mounts from my truck.
--Eric
In The REAL Norcal...
2005 Taco DC 4X4
Discussion Starter · #31 ·
HotRod..good info to have.....think I'll go down to the hardware store and swap'm out......
Thanks!
Jay
so it's a consensus that these rocky mountains are laterally much stiffer than the toyota mounts? i have to tie my bike down so that it doesnt sway when cornering/driving over bumps, etc.. i dont want it to sway because i dont want to put undue forces on my fork..
thumbs up from everyone in terms of lateral stiffness?
thanks
2005 Taco DC 4X4
Discussion Starter · #33 ·
Yeah, they are way stiff laterally.....they only thing you "might" want to do is run a bungy from back corner to back corner through the rear wheels if your gonna really rip over some ruff stuff........
2005 Toyota Tacoma
thanks
No comparison! If you mount these correctly and tighten them down, they move no where! Great product! :clap:
I like the washer idea. Had one of my bikes fall over still attached to the mount. Scared the $hit out of me. Thought the fork broke.
2005 Taco DC 4X4
Discussion Starter · #36 ·
had the same happen 2 me....luckily it went into the truck!
FBJXR
'05 X-Runner
isnt it a pain in the ass every time you guys need to remove those? i just never know if i will need to put one of the rings where the fork mount could be sitting so i dont want to put anything in the rail that is this permanent.
2005 Taco DC 4X4
Discussion Starter · #38 ·
It's really not that bad.....I carry the torx wrench that came with it in the center console.....takes about 20 seconds to get them out......just unloosen a couple turns and slide out.....
2005 Toyota Tacoma
I almost never use a mount on that back rail. I use the two side rails for everything. Even if I needed the back rail, there's still plenty of place to put one of those withouth removing them.
Paseo/Tacoma
--Eric
Have you seen these in stores or would you have to order online? I went to my local Lowe's and they didn't carry torx bolts only torx screws. I'll have to check Home Depot next time I'm near one.
1 inch fender washers are a must for this mount the bolt that comes with it is shaped like an oval and is easily dislodged from the rail with some side-to-side force. When testing it I noticied that some of the paint on the mounts was coming off from the rubbing. So I decided to make one more small addition to the mounting hardware, a small rubber washer between the mount and the rail.
It also makes it feel slightly tighter and it only cost about 75 cents for two
21 - 40 of 54 Posts
