Vote for your ROTM for August.
  • FlawedLegacy
    Votes: 20 35.1%
  • BLUEMEANIE
    Votes: 10 17.5%
  • MR2Jedi
    Votes: 0 0.0%
  • Kiwi-Corolla
    Votes: 22 38.6%
  • Dimaoala
    Votes: 3 5.3%
  • eyeball96
    Votes: 0 0.0%
  • ONE_to_HATE
    Votes: 2 3.5%
Status
Not open for further replies.
1 - 20 of 34 Posts
Lowdown Lowlife
09 Corolla LE MGM
My ride:
09 Corolla LE
Top 3 Mods:
Honda Accord Type R lip
Self painted Enkei RS7 wheels, Lip Spoiler, Roof Spoiler, Mudflaps -color matched
LED Tails with Shft99's mod to extend LED's to inner part (and tinted)
since we're listing all the mods, here are mine:
Cold Cathode Trunk Lights
Cold Cathode Floor Lights
DeBadged
Bungie-Trunk (to help it open further upon keyless entry)
35% Charcoal Tint (Front, Rear, Back, Windshield strip)
Weather Tech Window Vents
Custom Fit Eyelids
Magnaflow Muffler with Double-Wall Exhaust Tip
Roof Spoiler
Lip Spoiler
TRD Springs
Fog Lights Added
Custom AC Insulation
Kenwood 2-Way Rear Speakers
Lo-Glow Rear Toyota " T " Logo in White (removed) -v2.0 coming soon!
Enkei RS7 17" Rims (custom painted with TRD resin decals)
LED Plate Lights
LED Map Lights
LED Reverse Lights
LED Dome Lights
Removed Stock Pinstripe, Added Custom Pinstripe
DDM Tuning 35w 4500k HID Fog Lights
DDM Tuning 35w 4500k HID Low Beam Lights
Custom Painted Color Matched front Calipers (MGM)
Custom Gas Shock Hood Damper system
White "T" front logo with "MGM" Vinyl backing
Pivot 3 Throttle Controller
Color Matched Mud Flaps
Luminics Pure Blue High Beam lights
Husky Weather Beater Floor Mats (Front and Back)
Takeda Retain Short Ram Intake
OBD II Splitter for OBD II Bluetooth Adapter and Pivot Throttle Controller
'98-'00 Honda Accord Type R Front Lip custom fit
Custom made Front Strut Brace
Removable Decal Windshield Banner
Side Mirror "Rainproof Blades"
LED Tails with inner led's added, smoked reverse/turn
Black out front/rear logos, diffuser
Custom Door Inserts
Scion tC arm rest with door insert matching fabric
Garage door hidden buttons (relocated opener)
Smoke Fog Housings
Currently Modding:
Spacers (1 set, awaiting studs and second set)
Wink 5 panel mirror
EDIT: on Sat the 27th, I will be installing Sub and putting on 9th Gen S Tech Springs.
I think that's it
'91 MR2 Turbo
Ferrea Stainless Steel valves(stock diameter)
Crower Springs with Titanium retainers
Shimless lifters ( from MR2 Spyder 1ZZ engine)
New seals and keepers
Resurfaced and vatted
ARP Head Studs and Nuts & Washers
Cometic Metal 1.0mm Head Gasket (stock thickness)
Block bored and honed .040 over
JE Forged Pistons .040 over with 9.0/1 CR
Pro Seal Rings
New Main and Rod Bearings
Polished Crank
New ATS Racing CT27 Turbo
ATS 3" Down Pipe
3" dual Exit Exhaust
12lb. Fidanza Chromoly Flywheel
ARP Flywheel Bolts
Spec Stage 2 Clutch
Greddy SM IC and Piping
9" Spal fan
Straight Thru Throttle Body Inlet
TRD Short Shifter
Oil Catch Can
K&N Cone Filter
Stock BPV vented to atmosphere
New Oil Pump
New Alternator
New A/C Compressor
New OEM Timing Belt
New Timing Belt Tensioner
Stainless Steel Braided Oil Line, Water By Pass Lines and Vacuum Lines
ATS Knock Sensor
Phoenix Power Front Bumper, Side Skirts and Rear Valance.
Toms Scoops.
Eribuni Rear Wing (7")
Front Tires/rims-17/40/205 Rikens on 17x7 XXR Extremes
Rear Tires/rims-17/40/235 Rikens on 17x9 XXR Extremes
KYB AGX 4 Way Adjustable Racing Struts all around
Greddy ProfecII Electronic Boost Controller
HKS Turbo Timer
Brushed Aluminum Instrument Bezel
Brushed Aluminum Laser Engraved MR2Shifter Base Plate
Autometer Digital Oil Pressure Gauge
Autometer Boost Gauge
Autometer Digital Volt Gauge
HiFlow Fuel pump
New Distributor
New Coil
New Ignitor
New FPR
New AFM with manual lean/rich adjuster
New Injector Resistor Pack
Sweet n' Lowdown
2006 Scion tC
The BLUEMEANIE's MOD LIST
2006 Scion tC
Wheels:
» Raiderwerks MTEN-80 18x8.5
» Custom paint (now matte black)
Tires:
» Falken 502 215/35 (baby stretch)
Suspension:
» Tein SS+P (Super Street + Pillow ball mount) coilovers
» Tein EDFC (Electronic Damping Force Control - 32 way adjustable from driver's seat)
» TRD rear sway bar
» DC Sports CS-2 strut tower brace
Body:
» Fenders rolled and pulled
» All emblems shaved w/the exception of the trunk (trunk emblem painted matte black)
Interior:
» AEM digi boost gauge
» PLX OBDII Bluetooth adapter to run Torque gauge assortment.
Tunes:
» Four Memphis Audio MClass 6.5" 15-MC62 coaxial speakers
» 4ch Fosgate 400a amp
» 10" Fosgate DVC HE2 subwoofer
» 600w Kenwood KAC-729S amp
» "Quick ditch" box custom made to the BLUEMEANIE's required specs by Memphis Car Audio rep (Thanks Fred!)
Engine:
» Vortech F-trim centrifugal supercharger @ 7psi (was 10psi on a NST 65mm s/c overdrive pulley)
» Atmospherically vented Forge Motorsport 007 Porsche/Audi By-Pass Valve (occasionally swapped out for an HKS SSQV III)
» Custom designed Saikou Michi DC3 dual chambered catch can
» Doctor Isotope air diversion plate
» DME aluminum radiator tie downs
» Chopped and adapted Injen cold air intake
Tranny:
» TWM Stage 2 short throw shifter
» Speed-Source brass cable and base bushings
» Custom made aluminum cage riser
Lighting:
» Lexus/Denso HID ballasts w/ custom wiring and re-based 4300k bulbs
» VRD glass fog lamps w/ Nokya "JDM Yellow" bulbs
Full Throttle
1993 Corolla SE Ltd
Heck, I may as well enter too :D
1993 Toyota Corolla SE Limited (JDM AE100).
Current mods:
Engine:
* Replaced engine with 60,000km (37,000 mile) 5A-FE.
* Full 2" exhaust with Dynomax muffler and 2x resonators.
* Custom 3" cold air intake (CAI) with Simota pod filter.
* Header and front pipe (4-2-1).
* Removed the catalytic converter.
* TRD spark plug leads.
* Red valve cover.
* Chrome Simota oil cap.
* Oil catch can.
Exterior:
* OEM AE101 FX-GT front bumper & aftermarket lip.
* Genuine OEM Koito Toyota BZ Touring headlights.
* BMW M3 trunk lip spoiler.
* Aftermarket fibreglass sideskirts.
* 35% "Night Rider" window tint.
* 17" Advanti Photon alloy wheels (Hyper Silver).
* Rolled rear fenders.
* Front/rear bumper lips painted.
* 'SE Limited' and 'Toyota' badges removed.
Interior:
* Toyota Corolla GT seats + folding rear seat conversion.
* AE101 FX-GT SuperStrut Momo leather steering wheel.
* OEM Lexus IS200 aluminium foot pedals.
* Rare OEM factory option 'For Your Life Scene' storage drawer.
* Ultra-rare OEM factory option 'Air Fantasy' fragrance control system.
* Rare OEM factory option Air Purifier unit.
* Rare OEM factory option motorised driver's seat rail.
* Rare OEM factory option key light.
* Rare OEM factory option floor-well lights.
* Rare OEM factory option velour extended armrest with storage compartments.
Brakes/Suspension:
* Lowered on Jamex springs.
* TRD 3-point strut brace.
* Monroe GT Reflex gas shocks.
* Resurfaced front disc brakes.
* Bendix brake pads.
Audio:
* Sony Xplod USB head-unit.
* Sony Xplod 6.5" 4-way front speakers (75w RMS each).
* 6.5" 3-way rear speakers (95w RMS each).
* Sony Xplod 4-channel 444w amp.
Not saying any names but... I don't know if some of you guys read the rules but its only suppose to be one pic of your ride... ;)
RULES FOR ENTRY:
- Must be a Toyota, Lexus or Scion.
- One picture max of your ride, so make it the best one.
- Please don't take down the picture after it has been posted in the nomination thread.
- You must be the owner of the vehicle to win, no pics of your friends vehicle.
- Pictures that have been altered are not accepted, but you can cover the license plate number up.
- After 10 days five rides will be chosen at random and entered into a voting thread.
RULES FOR CONTEST:
- Voting for ROTM will be open to members for 14 days.
- Winner must be a member in good standing or runner up will win first prize.
- In case of a tie, Toyotanation Staff will vote on who wins.
- You must have 100 posts and be a member for two months to vote.
- No campainging for votes in threads, but you may advertise for votes in your signature.
- Voting will end at midnight EST on the 24th of each month.
[g4.Rep]
1999 Toyota Camry LE
I nominate.. my faithful servant for 5 reasons :)
1) Has driven 8 going on 9 kids from elementary/middle school to their HS graduation.
2) Drove her to my first job up to my first day in my career.
3) Never missed any christenings, weddings, & court dates (for all her fix it tickets).
4) She's parked by herself at meets and never won a show, but always comes in top 50 (LOL! at least in my book she does!).
5) Always started up in the coldest mornings, and hottest days to help me become the person i am today.
I'll throw two in... of the StL members
Myself
My ride:
09 Corolla LE
Top 3 Mods:
Honda Accord Type S lip
DeBadged
Custom Fit Eyelids
Roof Spoiler
Lip Spoiler
TRD Springs
Fog Lights Added
LED Plate Lights
LED Map Lights
LED Reverse Lights
LED Dome Lights
Custom Door Inserts
Smoke Fog Housings
Currently Modding:
Wink 5 panel mirror
I think that's it
So is it a Type S or Type R lip? ;)
:facepalm:
FAIL..
I shall use your quote for this! :naughty:
We need more 8th gen Corollas in here so I nominate myself, assuming this is still open:
Mechanical:
- custom cold air intake
- NGK Iridium spark plugs
- NGK spark plug wires
- JDM Trust muffler
- KVR cross-drilled rotors
- Hawk HP brake pads
- Neuspeed lowering springs (front)
- Tein S-Tech lowering springs (rear)
Interior:
- white face gauges
- custom red dash lights
- plaid headliner
- Wink 5 panel mirror
- TRD seatbelt pads
- cheapy JVC stereo
Exterior:
- Rota GT3s, currently painted flat black
- BLOX Racing extended lug nuts
- VIS carbon fiber hood
- JDM power folding mirrors from 7th gen Corolla
- side window visors
- rear window visor
- bike rack (which gets used)
- clear front corner turn signals
- custom side marker lights
- red rear turn signals
Mods in progress/future plans:
- Corolla s sideskirts
- custom front lip (not the cheapy Home Depot lip)
- full TRD 7-piece lip lit
- 8.5 front end conversion
- 5-speed conversion
- new paint (tired of the purple, even though it's rare)
- full coilover setup within the year
- better intake setup
- full exhaust setup
1 - 20 of 34 Posts
Status
