1 - 8 of 8 Posts
Originally the car stopped at a stoplight and the engine turned off by itself. It turned on again but the car would not move and the engine died again. We had the car towed and it just started up by itself the next day. We changed the spark plugs a few days later and after that there was a low sound coming from the engine.
The engine makes a gasping noise every few seconds while idling. The RPM's are normally steady at 1000, but when the engine makes the noise the RPM's drop to about half.
Update- The car had a P0340 trouble code. What could be causing it?
96 camry 2.2
My brother had a similar experience when his water pump was going out. It seized enough to kill the engine, but would later crank and run poorly and have a bad sound. It died while slowing for a stop sign. Check to see if your radiator fluid level is good and examine the weep hole on the water pump for signs of leakage.
Discussion Starter · #3 ·
The water pump and timing belt were changed recently.
Administrator
All by itself?!?!... No one turned the key?
P0340 = Camshaft Position Sensor Circuit Malfunction. Most likely the sensor has gone bad. Could be a wiring problem, but unless someone's messed with the wiring harness recently, chances are it's the sensor.
Discussion Starter · #5 ·
No. we did turn the key to turn it on, but I meant that the car seemed to work fine the next day.
Where would the sensor be located on this Toyota?
Administrator
^:lol:
Actually, we did have a thread a while back where the car was starting itself!! That's why I asked. IIRC, it was an aftermarket remote starting unit going on the fritz.
The cam position sensor is near the cam pulley...
Look in sig
Sounds like the sensor is going the fritz and causing the car to run off. That or the belt jump timing.
1 - 8 of 8 Posts
