Hi folks,
I have an autozone RPM gauge. It gets signal from the diagnostic port next to the fuse box for several years. It's a 22RE manual with 119k mi.
Recently the RPM needle jumps erratically over the RPM range. Mostly happens at 1st cold start of the day or sometimes during the day even after warmed up. Could this be a electrical only issue? For example, I am positive the engine is not running at 4k ~ 5k RPM at 60MPH with 5th gear...because engine still sounds running at ~2.5k.
Where should I diagnose first?
