1 - 12 of 12 Posts
Hey guys whats up? I just installed my revtek 3 inch system. I am running 285/70/17 on my truck with the stock wheel. I am geeting some rubbing from the upper controll arm. Iam wondering happening. Is it b/c i need a different wheel size like the an 8 inch wide wheel or what. If any one knows why this is happening or if anybody eleses truck is doing the same thing please let me know. I was also told to use 10mm spacers but iam not sure about that either.
Thanks, Nick
Tacomania
You should be good with a 1/4" spacer on each side. You can get them at most offroad shops.
WAX museum.
2005 Tacoma
Yes, it should get rid of the clearance issue, but I would rather get new wheels than run spacers. I've had bad luck with them. Plus that's just MORE unsprung weight.
Ive got the same exact setup as you (checkout my cardomain page). I had to install 1/4" spaces on the front to clear the control arm. It works fine now, there is only rubbing when I go into reverse at full wheel lock.
Dont listen to these other guys, its not their money or time... just get the spacers if you are happy with your setup.
Engine 80 is in service
'10 FJ Cruiser 4x4
I was going to point out your truck as an example... but, I couldn't remember your SN. :eek::
1 - 12 of 12 Posts
