1 - 8 of 8 Posts
When I was first considering the 08 Tundra I read something about the rumble strip, a problem with the torque converter. Yesterday when I drove my new truck, 08 Tundra, 5.7 4 wd, crew cab, I stepped on the gas and felt something strange as it shifted. I thought I had run over something. It only happens when rolling at about 45 mph and you gas it. Could this be the dreaded rumble strip? I put the words in the search and didn't come up with anything. I thought the problem had been corrected in the 08.
Yes it could definatley be the rumble strip, as you drive your truck more you will notice it more, it usually happens when the truck is running at low rpms and then you have to gas it a bit to go up a hill or speed up and then its honestly like driving over rumble strips on the highway, the exact same feel sound vibration everything, you cant miss it.
Then you definatley have the problem, its a new torque converter and it will take toyota about 8 hrs to do the job, that how long it took them on mine, they were really good to me, supplied me with a brand new toyota 4 runner to drivfe while they worked on it, but I am really good firends witht he general manager so I guess that helps,
2008 Tundra CrewMax
I have an 08 crewmax. Almost immediately, I noticed a slight vibration. At first, I attributed it to bad Louisiana roads. I quickly realized a pattern: it usually occured after taking off from a stopped position; it usually occured when I was accelerating conservatively; it usually occured around 30-35 miles/hour. When I brought it in for service, the mechanic had a difficult time duplicating the "rumble" so I had to drive it for them in order to point it out. He was unaware of this type of problem prior to my truck. After all is said and done, I have a new torque converter on order. Hopefully this will fix the problem.
Reviving a dead thread!
Just picked up an 05 tundra dc 2wd and get a rumble strip in a different way than what I have read. Traveling 70mph let off throttle and rumbles for a quick half second, touch the gas and rumbles again for a half sec. hold the gas just barely (not quite enough to maintain 70mph on flat ground) and it’s a constant rumble. I’ve replaced the center u-joint and carrier bearing and it has reduced this effect but not eliminated it......
1 - 8 of 8 Posts
