Hey all,
I have a friend that owns a 4-cylinder 1991 4Runner. It's been a money pit!! I want to relay what she's told me of her problems in the hope that someone might have any suggestions...
Her vehicle constantly overheats. It's been doing this for a long time. She's had the head gasket replaced twice and the engine replaced (from a wreck - no rebuild) once. These solutions didn't solve her problem. I took it to a radiator dude and he said that it was shot (it was trashed!) and replaced it. This seemed to help the heat problem for a while, but it has happened again.
After she got her engine replaced (in about June), when I dropped her off and followed her, I noticed a lot of white smoke coming from the exhaust (even though it was 25C outside that day). I had her pull over and it seemed that the exhaust smelled like coolant. About two days later, the Check Engine light came on.
Even after her radiator was replaced (in July), the smoke still wafts out of the exhaust. It's most noticable when the vehicle has sat long enough to cool down (ie. overnight). It does seem to go away, or is much less obvious, after driving it for a while.
I pulled the EFI fuse to reset the codes and it came on just yesterday.
I'm trying to figure out what the problem is. After researching the issue on the 'net, I'm leaning towards a manufacturer defect that causes the head gasket to leak. I haven't inspected the plugs, oil and "Check Engine" code yet.
Has anybody experienced a problem like this with the same engine? Or, can suggest any diagnosis procedures?
Thanks for your help!
Dean
Dean
