The water pump is all metal with rubber rings and bearings. There's a weep hole on it right behind it's pulley. If it leaks coolant from there and/or around the water pump itself, or make abnormal sounds and what not, it's time for a new one.
As for your radiator, make sure it's clean and the fins are not all dented and stuff.
For complete internal cooling system check, do a flush. If everything flows right, no clogs.
For antifreeze, buy the 50/50 antifreeze and fill the cooling system with that. Personally like the green 50/50 mix from Prestone, never done me wrong.
