1 - 9 of 9 Posts
08 Toyota Corolla S
I need to pass wires through the firewall so I can install LED lights into my foot wells, does anyone know of a place to pass them through?
Thanks
Full Throttle
1993 Corolla SE Ltd
08 Toyota Corolla S
Is there pictures on the 9th Gen where I can specifically find these? I looked at both the threads and there's no specific location given excluding the passenger's side. But where exactly?
Thanks
04 Corolla 69 Chargr
for no more current then you will be drawing (probably) there are a ton of points you could pull power from- the power points/cig lighters spring to mind. there are others-
just a thought. I have drilled a hole through the fire wall (wouldnt recommend) and there are lots of places a small wire could piggyback thru
2012 Camry+2014 Sienna+2007 Corolla+2014 Corolla
I'm trying to get an RCA connector thru the firewall of a 2007 Corolla, it's 3/8" in diameter and so far no luck finding a way to do so. I hate to drill a big hole and had to silicone up, so I'm looking for the easiest way to do this. Anyone?
I had to slide a four pin connector much larger than 3/8 for my fog lights. I did it through the common wiring harness grommet. I taped it to a Philips screwdriver, after silicone spraying it. Was fine. I did it all the time when I I stalled radios.
You may of course amputate RCA plug and reattach or attach a new one. Many years ago, I'd prefer USA-made Switchcraft brand for good performance and not too bad pricing. Parts Express offers many choices now. HTH.
I found the common wire grommet you mentioned above, it's pretty tight I'm not sure the grommet will stretch enough to get my RCA plug thru. I'll give it a try hopefully it'll work.
I try not to cut and reattach the connector, chances are I'll screw up.
Trust me. If I can fit a flat four pin connector through, it'll be fine. I'd also recommend taping up the end of the screwdriver as well.
1 - 9 of 9 Posts
