1 - 6 of 6 Posts
I had new tires balanced and aligned in summer 2018. The tire tech took quite some time using a torch to adjust the alignment as the tire rods are so rust. Finally got it all green passing. Fast forward to now. I had them check the alignment again, the front driver is a bit off. Any chance rusted tie rods can cause misalignment? What other parts should I be checking for. Currently has 211k miles. Sienna CE 2009.
01 Avalon XL, 03 Avalon XL
It's more likely that a brand-new tie rod would drift (if the stopper nut hadn't been tightened enough to keep it from turning).
Assuming this is toe-in, how much difference between 2018 and now? Are you experiencing steering problems, or abnormal tire wear?
If it's a tiny difference, the shop may have calibrated their equipment since 2018, or misread either the 2018 measurement or the current one. Other than that, changes come from pot-holes, or any kind of wear or shifting from steering rack to wheel -- rack, tie rod ends, wheel bearings, lower control arm, possibly though not very likely with toe, the strut top bearing.
This. If it's in spec don't worry about it.
The alignment is a bit off on the driver side. It does experience wheel vibration at 70 - 80 mph speed. Low speed no feeling. The tie rods have never been changed. Original from 2009 on the car.
1 - 6 of 6 Posts
