The S mode confuses a lot of people but I will define it the way I see it. First remember your Venza is a 6 speed transmission. The 5th and 6th gear are basically for highway cruising/gas mileage. They reduce the engine RPM's so you can cruise along with a quiet engine consuming less gas. Second the "S" does NOT stand for Sport. It stands for "sequential". The Sequential mode locks out 5th & 6th gears. Sequential mode is great around town because if your transmission shifts up to 5th & 6th around 40 mph and so, it is very slow to respond if you need quick acceleration. Also if you have mountain roads you can shift into Sequential to go up or down the grades. In Sequential you can tap the gear shift to the left to manually drop down a gear. Example coming down a hill--- you shift to S mode now you are locked into 1,2,3 or 4th gear, if you want to hold your Venza back without using the brakes you can tap the shift lever to the left to change from 4th to 3rd or from 3rd to 2nd. You cannot shift from 2nd to 1st because Toyota locked that option out. To shift up {2nd to 3rd or 3rd to 4th} you tap the shift lever to the right. GOING UP the hill if you need more power for the climb and/or turns, S mode lets you manually shift down for power, just like going down hill shifts hold you back. If you do not have hills to drive, use "S" for in town driving {under 45 MPH} it will give you a quicker safer response. I hope this helps a little, it is much easier for those of us who have driven manual transmissions. S Mode is kinda of a manual tranny without a clutch pedal. It is truly a great transmission. I wonder if many Venza owners actually understand and use the S mode much. Just experiment with it, you will like it. WyovenzaSomeone please explain how do i use the S-mode in 2011 Venza. Is it better to use then normal drive. I read the manual but still don't understand. :facepalm:
The Streets are one of the primary uses for the S mode. In 4th or lower gears the engine RPMs are higher so the engine will make a little more noise but it will respond quicker if you have to accelerate quickly. It will also slow down quicker when you take your foot off the gas pedal. Consider the "S" mode to be a "Street" mode under 45 MPH.So the s-mode is for up or down hill? So if I drive through the streets I can use it? I tried using it driving 35 and in 4 that's fine? It just doesn't sound right the engine
Good advice: --there is precious little fun driving an automatic and the S mode gives you something to play with..but ...if you are nervous then wait until you are on a quiet back road to explore. It really is no biggie..I don't bother with it that much on the Venza.Meelinda, we bought our venza and my wife was the primary driver. I didn't drive it much, but when I did I treated the automatic like an "automatic" - meaning that I'd let the car decide what to do. To me, that was the idea behind "automatic". I didn't drive ours enough to really worry about it and would likely drive it differently now (using the S mode), but I'd suggest you not worry about playing with the gears and let the car's transmission make the decisions for you. I think the car is likely programmed to optimize fuel economy and would be surprised if you'd notice that much of a difference in mileage. But you may be jeopordizing your own safety worrying about what gear you were in or how many rpm's you were running. So I say relax and enjoy the car. Don't worry about the gas mileage as there's little you can do to impact it except when it's empty - you get two choices - refuel or park.
Meelinda. I do agree totally with this Throck post. I think in your case you should just put your Venza in drive and relax. Relax and let your Venza do her thing.Meelinda, we bought our venza and my wife was the primary driver. I didn't drive it much, but when I did I treated the automatic like an "automatic" - meaning that I'd let the car decide what to do. To me, that was the idea behind "automatic". I didn't drive ours enough to really worry about it and would likely drive it differently now (using the S mode), but I'd suggest you not worry about playing with the gears and let the car's transmission make the decisions for you. I think the car is likely programmed to optimize fuel economy and would be surprised if you'd notice that much of a difference in mileage. But you may be jeopordizing your own safety worrying about what gear you were in or how many rpm's you were running. So I say relax and enjoy the car. Don't worry about the gas mileage as there's little you can do to impact it except when it's empty - you get two choices - refuel or park.
Well maybe..Meelinda try to have some fun..find a lonely back road..play with your nice Venza. The more you understand the transmission the safer you will be. Leaving it in automatic is fineMeelinda. I do agree totally with this Throck post. I think in your case you should just put your Venza in drive and relax. Relax and let your Venza do her thing.Sometimes things should just be left on Automatic. Wyovenza
Downshifting CAN save gas. And save brakes. Normally when I leave the highway (much like interstate in the US) and I end up on a stop sign, I'll start reducing speed by downshifting to 4th then to 3rd and 2nd.I'm starting to get the hang of it. If my RPM is at 3 I Chang my gear to 3 and when it slows down down to 2? Does this help save gas?
