ok so i got a set of rear disc brake conversion form a fx16 gts and so i bolted everything up, now i have a questions, for some reason i looked up and the fx16 has same rear strut as ae92 and i used the ae101 shocks and spring combo(cheaper) and my stock drum brakes bolted up fine with the ae101 struts, now heres a kicker, the fx16 hub in the rear where it bolts up to the strut, only one hole fits and the other doesnt? now my question is, how come when i looked it said same part number from fx16 and ae92 sedan for rear struts? and why doesnt it fit? i also want to know if is it safe to run only one bolted in? or should i just take them off? everything was easy to install, and then when i noticed that only one bolt was going to go through the strut to hub it was dumbfounded, i retightened the bolts back together, and pushed in the tires so it doesnt butterfly to the top anymore so the tires wont scrap the struts(first time tightened it while jacked, second time tightened it while sitting on the ground) but im still concerned about having only one bolt on the strut to rear disc hub... is there a reason why there is two holes there? someone out there with the answers please get back to me... just dont want to wreck the corolla...
