since my camry blew up its seccond trans, im strongly considering selling it. i looked up in the KBB, and it said for a car like mine, in the shape its in roughly $2k, and im going to subtract about $500-$700 for a transmission replacement.
its got: new front- shocks, brakes, steering rack, spark plugs, cap, rotor, wires, PCV valve, front valve cover gasket (i have and it needs a back), WATER PUMP, and TIMING BELT!, CV SHAFTS (both), rear brakes, head lights (highs and low's)-silverstars, radiator, both front window reg's, battery, drivers side interior, and exterior door handles, Y-pipe, and cat, thats about all i can think of...
I have at least $3000 invested in the car, but then there's the bad...
paint is dying in the front, clear coat is chipping off around the door, and hood mostly on the driver's side, the trans. is hardly usable it will shake you to death when trying to go anywhere, the back shocks could use an update, but they are working well for now, probably will last a good bit longer, thats about all the bad there is on this car.
so what do you guys think? im kinda tired of shoving money into it, most likely after i put a trans in it, the motor will explode, shredding the whole car into a million pieces. my time with this car is nearing an end.
anybody want it?
anybody want it?
