hello fellow eggmen.
i bought a 95 previa all trac with a rebuilt title and about 155555 miles on it. I had a guy who is a mechanic change the spark plugs, valve cover gasket, wires, cap, distributor, rotor, and o ring and replace an exhaust gasket so it no longer sounds like a harley. (now is sounds like a whistle).
My goal with this vehicle is to have a car that will take me camping and to the ski hills without a ton of $$ investment. And I'd like to do as much of the work as I can. My next project is replacing the bushings on the sad shaft.
My friend told me the polyurethane bushings are better than the aluminum ones with rubber grommets so I got ordered one from here:
http://cgi.ebay.com/ebaymotors/Toyo...tors_Car_Truck_Parts_Accessories#ht_812wt_958
I have heard that the job is relatively easy to do and I can see the parts that I will be replacing, I am hoping someone here can walk me through the steps to do this with the least amount of headache and lost skin. even better if you have pics but not neccesary.
Thanks for your help
BarStar (BS)
BarStar (BS)
