1 - 20 of 22 Posts
Tragically Hip
I like it...Good work on this application.:thumbup:
2012/14 Stanley Cup Champ
You can also buy plastic paint that is color matched to the interior. I'll try to find the exact paint to use, but I've seen plenty of custom installs with painted parts.
Forumatic Immunity!
05 Taco DC LB V6 TRD
Pb said:
Looks good. Is that ABS plastic? What did you use to cut it? Razor blade, Dremmel, hot knife?
FYI, I get my ABS plastic sheets from here. http://www.partsexpress.com/pe/showdetl.cfm?Partnumber=265-940 They have 3 different thicknesses available.
Thanks.
I am gonna do something like that for my aux lights overhaul and put the 4x4mods rocker switches there that i am mounting on my rack. :)
good job KPSK
Surfing TN via iPhone
05 Tacoma DC 4x4 TRD
Fluxaholic said:
Pb, in your experience, what thickness is easiest for cutting with a dremel? Also, any prep work needed for painting?
It depends how big of an area you are trying to span. The thicker, the sturdier. To do most of the cutting I usually use a disc that is made to cut plastic. I like the new E-Z lock discs. There are discs for cutting plastic, and discs for metal. http://www.dremel.com/en-us/attachments-and-accessories/attachment-accessory-detail.htm?H=189191&G=69875&I=69880
Then I'll clean up the edges with a sanding band on the Dremmel, and then a peice of fine sandpaper by hand. http://www.dremel.com/en-us/attachments-and-accessories/attachment-accessory-group.htm?H=188569&G=66408
I'll use a hand file to finish up sharp corners.
I haven't painted a lot of ABS. I would just wipe with alcohol and then paint.
07 TACOMA TRD SPORT
Discussion Starter · #17 ·
Yeah I like PB's also, but wanted to keep my compass and all. I am glad you all like and was happy to share something from a group of good peeps that have helped me out also.
Forumatic Immunity!
also, KPSK can you give me the dimensions of the peice and what paint you used on there. please. thanks.
Just got threw doing the mod , went real easy . For the piece of plastic I went to the local sign maker and got a 12" by 12" light gray plastic panel for $2.00 , cheapest place that I founded . Going to paint it to match interior .:clap:
1 - 20 of 22 Posts
