1 - 6 of 6 Posts
What is a Scanguage II?
2002 Camry
Looks kinda cool. But myself I dont have a "scangauge" nor do i need one - i bought a $30 scanner from harbor freight and i use it if the CEL comes on for no apparent reason, it reads the codes, if any, and shuts the dam light off if nothing is wrong -
2008 Prius
Scangauge
Yes I have mine on a 07 SE V6 works fine constant readout of rpm, water temp , miles per gallon and volts. I also use it on my 06 Jetta Diesel . It just connects to the OBD 2 port under the dash. It will also give fault codes if one occures.Sgt Tip
1 - 6 of 6 Posts
