You can gain access to all of the same info that the dealer has by paying for a short (or long) term subscription to
A 2-day subscription lets you save as much info as you can find by printing to a PDF. The site is a bit cumbersome but you can figure it out in an hour or so. You can see schematics, harness information, even harness pin part numbers. You can also do any amount of repair desired with similar access as the dealer has. The schematics are in one piece online but print out on multiple pages.
I've gathered as much audio info as I needed for my 2019 SE (and some extra) to identify the wiring harnesses and wiring colors for the base and premium head units. There are also location maps of the interior harnesses for my SE and the harness pinout numbering is at the end of each head unit file. Note that the XLE and XSE will have some variances and I didn't try to find all of the info for those vehicles since it's based on the VIN.
I'm sharing the files in my onedrive account here:
Enjoy.
Sadly, Toyota doesn't make deciphering the harnesses as easy as the techinfo.honda website does.
If you have any questions about snagging the factory signal and adding aftermarket equipment, feel free to ask. I will be re-pinning the door molex plug to increase the factory door speaker wiring size (smaller than 18ga stock) along with upgrading drivers. I've 3D printed dash speaker adapters, ran power wire through the factory grommet with factory wiring, and will have a JL VX1000/5i under the driver's seat of an SE shortly. The BT signal is injected into the right front speaker wiring at the telematics receiver, this appears to occur after the head unit output. That means snagging the audio signal at the HU may neglect the phone audio, only for it to be mixed in later. I'd like to bring that into the VXi separately so I can control the mix myself and will experiment in the coming weeks. I plan on re-pinning the harnesses to snag signals instead of cutting any factory wiring.
Cheers
Enjoy.
Cheers
