1 - 4 of 4 Posts
I realize this issue is involved with the struts or ball joint or rubber bushing but was just curious if there was a common culprit?
car began making this noise on passenger side last summer after i hit some hard corners at high speed.
the sound is more common when it is cold out which is a lot here in alaska, it is now on both sides. it doesnt do it when i turn the wheel lock to lock and i cant get it to happen by bouncing the car by hand. it only seems to do it at slower speeds (less than 30 mph) or on sharper bumps. it's basically a squeak but has more depth.
i tried to search but my jedi search technique sucks.
Default User Title
Camry GEN 3
Try your rubber bushings on your rear sway bar. They are notorious for deteriorating around this time of the car's lifetime. The squeak always came when I ran over a speed bump but was never really there at any other time.
sorry, should clarify
the noise if from the front, 95 with 101k.
rear has a mild thump when i hit bumps but im pretty sure thats a bad strut mount
1 - 4 of 4 Posts
