1 - 14 of 14 Posts
I know that the front bumber is different, but does anyone know if a lip kit that looks similar to the SE? I think that the side skirts and rear lip would fit just fine.
Abyways, thanks for your help!
Polish Pleasure Member
Car
This might interest you...I think it's better looking then the RKSport kit and you can probably get it from your Toyota dealer...
It's called the Special Edition Grounds Effect Package and below you can see it installed on an LE. I've been thinking of getting it when I order a hybrid later this year. Here are the pics I took...
2007 Camry TCH
The problem is that this Special Edition kit is not a Toyota factory OEM kit. This is a kit that was made for Southeast Toyota regional dealerships, that you can only purchase thru Southeast Toyota dealerships. I'm not even sure they will sell you the parts alone, it might only be a DIO when buying a new car.
You cannot order the Toyota OEM SE lip kit for the hybrid, because the SE bumper has special holes for mounting the factory kit. Of course, you could also buy the entire SE bumper, because that would fit on the hybrid with no problem.
The Razzi kit is the closet aftermarket kit to the factory SE look. I've confirmed with Razzi that it will install onto the hybrid with no problem. I'd order the kit right now if it wasn't so damn expensive, it would be about $1300 after painting. I'm waiting for the price to drop.
http://www.razzi.com/vehicles/toyota/camry_07CU_4dr_2393.shtml
07 camry xle i4
correction you can add oem lip kit to hybrid frt bumper ... holes have to be made but its an easy install for any one familiar w/ vehicles asembly .. so yes oem lip kit can be added o any model le ce xle or hybrid.. and the dealer will do it too for a small fee
That's not a Hybrid though
Car
If you read my post I did mention it's a LE. And since the LE and THC share the same body, I don't see a problem installing this kit on a THC.
You are correct. Sorry for the misread. Isn't there special aeordynamic thingies with the Camry hybrid?? Spats, undercarriage, etc...
06 Camry LE I4
$3000 for that kit :confused:. I will buy other real performace parts instead of that kit which is only for look. Maybe just get a SE.
2015 Subaru WRX STI
I agree, for that price it would probably be cheaper to trade in an LE for an SE model.
1 - 14 of 14 Posts
