Second Horn
2126 Views 16 Replies 7 Participants Last post by  92pickmeup
1 - 17 of 17 Posts
With any kind of air horn, this circuit will blow the factory 10A fuse as soon as you activate the horn button and the added switch is on. Well...maybe the 2nd time. How do I know this? I made the same mistake and I'm an Electrical Engineer! The air compressors for the air horns have a huge starting current, probably about 10-15A. I just followed the instruction that came with the air horn, which said the added relay was optional. Mine is wired with no added switch. Since I have only 1 horn, I used the unused 2nd horn connector to actual the coil of the added relay and then an 8A time delay fuse from terminal #30 to the battery.
Shouldn't the relay just trigger a release valve for air horns while another line straight from the battery runs the compressor? I'm thinking about an actual compressor with tank, pressure switch, etc.
Also, you could just use the factory horn wire to activate the relay (pin 85), and have pin 30 run fused to the battery. That would bypass the stock fuse.
I use the factory horn wire like Tiger suggested and ran a hot wire with a fuse link straight to the compressor.
a lot of the smaller air horns don't have a tank, just turn on and off the compressor, the whole unit is about the size of a beer can and then tubing to th horns themselves
so there is a pretty good current draw when first turned on !
forget where but another post about using a relay as they blew the fuese each time they hit the horn when just swapping plug from stock to small air horn
and remember ( at least back in the old glass fuse days)
if i have a 15 amp fuse and hit it with 12 amps several times you can see the filament dip and just a matter of time till fatigue and it blows
note: beer can size is considered a official carolina alliance measurement ;-D
I thought those other horns were designed to replace stock ones, and as such wouldn't blow fuses. Then again, I never did see wire diagrams for them so.... :dunno:
You wouldn't happen to be the same phantom on TW would you? Since you mention the carolina alliance and all.... ;)
ooops , my cover is blown ;-D
What kind of air horns are you talking about?
When I press my stock horn button in the steering wheel it sends voltage to either the stock horns or to the air solenoid valve, which then opens up and lets the air flow to the horns. I have a spdt switch that controls whether the stock horns are Live or the air solenoid is Live. The solenoid pulls less current than the stock horns, so there's no relay needed. This circuit has nothing to do with the compressor motor.
The air compressor motor circuit consists of 8 gauge power wire from the battery, to relays, which are controlled by a pressure switch on the tank. The relays are also controlled by a switch in my cab. The switch has to be On, and the pressure switch on the tank has to sense low pressure, and then the relays will be engaged and the compressor will turn On, filling up the 5 gallon tank and the air line that runs up to the front of the truck where the air solenoid valve is.
Oh, are you talking about this kind of horn?
That's childs play.
i just looked online at one of the install instructions for the small beer can air horns
and they include a relay as they want the horn fused at 30 amps and one model at 40 amps ( wow )
but on a real horn the solenoid probably pulls less than 10 amps for sure
ya i see you just posted and like that one ! same family but with the horns separate and a compressor like that
so on the "toy " ones i would use the horn relay to trip your relay wired up to a higher current fuse
note the size of the fuse they recommend !
from their instructions for a small 2 trumpet horn
so if wired per the chart at the start of this topic and current approaching 10 amps it would blow after a few times
this would work best for larger currents
^ Instead of adding that extra relay why not just do this?
Cut the 12v+ wire going out to the stock horns, connect it to #85 on the relay.
Pb- Were you up too late last night?
' Cause the circuit above has your factory horns blowing constantly -well, until you blow the air horn. (Battery to 30A fuse, to pin 30 thru norm closed contact to pin 87a, thru 10A fuse thru horns to ground.) :eek:
:lol: I was thinking the same thing. Then he mentions moving the horn wire from 87a to 85. That would work. :D
Yeah you're right. I overlooked that. I guess it would take two relays.
How about this? (like I said add others...:D)
Yes, that will function without blowing the 10A fuse.
That's childs play.
Yes, that's one of them. It also comes with a relay. Mine is similar, but has dual horns that are separate instead of integrated. The "beer can" compressor is the same on all.
1 - 17 of 17 Posts
