1 - 20 of 33 Posts
C
Guest
Does anyone know how to program the securikey+ for a 2000 Tundra. Lost
mine and bought a new one . Is there a manual on it? Where can I get
it? :( Any help would really help :D Thanks in advance
Posted using the http://www.autoforumz.com interface, at author's request
Articles individually checked for conformance to usenet standards
Topic URL: http://www.autoforumz.com/Toyota-securikey-programming-manual-ftopict123864.html
Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.autoforumz.com/eform.php?p=602991
I
Guest
Discussion Starter #2
> Tundra. Lost mine and bought a new one . Is there a manual on
> it? Where can I get it? :( Any help would really help :D
> Thanks in advance
I have a 3-button securikey+ remote 1999 Toyota Camry that I need to
program. The instructions I found on the interent do not seem to
work. Any help?
ImRockDoc
C
Guest
Re: Re: securikey+ programming and manual
> need to program. The instructions I found on the interent do
> not seem to work. Any help?
> ImRockDoc
Does it have a green button and the key is part of the remote? The
alarm is for the Gulf region. If this is what you have, PM me and I
will send you a copy of the manual in pdf format.
I
Guest
> The alarm is for the Gulf region. If this is what you have, PM
> me and I will send you a copy of the manual in pdf format.
Yes. My remote has a key and 3 buttons. Thanks.
ImRockDoc
I
Guest
> ImRockDoc
Gulf States Toyota just e-mailed me a pdf file of the instructions.
If anyone needs them post your e-mail address.
ImRockDoc at @ at yahoo.com
W
Guest
Discussion Starter #6
> instructions. If anyone needs them post your e-mail address.
> [email protected]
Could you please email me the .pdf manual for the securikey. I just
got a 2000 Toyota Tundra in Texas last week and can’t sort out how to
use the key. Thanks for your help
F
Guest
Discussion Starter #7
> [email protected]
Please send me the securikey programming manual
ImRockDoc
Please send me the manual.
Thanks,
kperry7505 at @ mac.com
SecuriKey+ manual
ImRockDoc said:
> ImRockDoc
Could you please send me the PDF? Thanks!
JKM
For SECURIKEY+ system
PROGRAMMING ADDITIONAL or REPLACEMENT TRANSMITTERS
Each SECURIKEY+ system can be operated by up to four (4) different
SECURIKEY+ transmitters. The system is supplied from the factory with two
(2) transmitters included, and additional transmitters are available through
parts distribution. Any new or replacement transmitters will need to be
programmed to the main control module before they will activate the system.
The SECURIKEY+ main control module uses a six (6) channel radio frequency
receiver; each channel controlling a different function of the SECURIKEY+
system. Each transmitter button can be programmed to only one of the
receiver channels (e.g., the GREEN button cannot be programmed to operate
the headlight feature and remote start option; it can operate only one or
the other feature). The following is a list of each receiver channel, and
the function of each channel.
CHANNEL # FEATURE CONTROLLED BY THIS CHANNEL
1 Lock
2 Unlock
3 Trunk Release (optional kit required; not available on all models)
4 30 second headlight activation (only if required by GREEN button)
5 Remote panic (only if required by GREEN button instead of LOCK
button)
6 Remote start (optional kit required; not available on all models)
To program new or additional transmitters, or when adding options to
existing SECURIKEY+ transmitters, follow the step by step programming
instructions found below. When programming, it is important to complete each
step of the procedure within 15 seconds, or the system will terminate the
programming mode. If this happens, simply start again.
Be sure that the SECURIKEY+ system is disarmed, and the lighted valet switch
is in the off (out) position before you begin.
Turn the vehicle's ignition key to the on position.
Press then release the L.E.D. valet switch 6 times.
CHANNEL 1: LOCK & Panic Feature Horn Chirps 1 Time L.E.D. Flashes 1 Time
To program the LOCK button on the transmitter, press and hold the LOCK
button until the vehicle's horn sounds one loud chirp. Repeat this for all
transmitters that need the LOCK button programmed (up to four transmitters).
After the LOCK button on all transmitters have been programmed, press and
release the L.E.D. valet switch 2 times to advance to the next receiver
channel.
CHANNEL 2: UNLOCK Feature Horn Chirps 2 Times L.E.D. Flashes 2 Times
To program the UNLOCK button on the transmitter, press and hold the UNLOCK
transmitters that need the UNLOCK button programmed (up to four
transmitters).
After the UNLOCK button on all transmitters have been programmed, press and
channel.
CHANNEL 3: TRUNK RELEASE Option Horn Chirps 3 Times L.E.D. Flashes 3
Times
To program the TRUNK RELEASE option on the transmitter, press and hold the
GREEN option button until the vehicle's horn sounds one loud chirp. Repeat
this for all transmitters that need the GREEN option button programmed (up
After the TRUNK RELEASE button on all transmitters have been programmed,
press and release the L.E.D. valet switch 2 times to advance to the next
receiver channel.
CHANNEL 4: 30 SECOND HEADLIGHT Feature Horn Chirps 4 Times L.E.D.
Flashes 4 Times
To program the HEADLIGHT option on the transmitter, press and hold the GREEN
option button until the vehicle's horn sounds one loud chirp. Repeat this
for all transmitters that need the GREEN option button programmed (up to
four transmitters).
After the HEADLIGHT button on all transmitters have been programmed, press
and release the L.E.D. valet switch 2 times to advance to the next receiver
channel.
CHANNEL 5: Separate PANIC Button Feature Horn Chirps 5 Times L.E.D.
Flashes 5 Times
To program the PANIC option on the transmitter, press and hold the GREEN
four transmitters).
After the PANIC button on all transmitters have been programmed, press and
channel.
CHANNEL 6: REMOTE START Feature Horn Chirps 6 Times L.E.D. Flashes 6
Times
To program the REMOTE START option on the transmitter, press and hold the
After the REMOTE START button on all transmitters have been programmed,
press and release the L.E.D. valet switch 2 times to advance to terminate
programming mode, or simply turn the ignition key to the off position to
terminate the transmitter programming mode.
PROGRAMMING THE SELECTABLE FEATURES
The SECURIKEY+ system offers a number of selectable features that can be
changed, allowing you to custom fit the system to your customer. The
following is a list of the features that are selectable and can be changed
using the valet switch and any transmitter that is programmed to the system
installed in the vehicle.
FEATURE # FUNCTION 1 CHIRP 2 CHIRPS
1 Headlights on for 20 seconds during disarm ON or OFF
2 Headlights on for 20 seconds during arm ON or OFF
3 Automatic ignition controlled door lock ON or OFF
4 Automatic ignition controlled door unlock ON or OFF
5 Auto unlock driver's door only or all doors Driver's door or
All doors
6 Active or Passive arming Passive or Active
7 Active or Passive door locks Passive or Active
8 Trunk release output - 1 second or latched 1 second or
Latched
9 Panic on lock button or option button Option or Lock
10 Trunk Release Hold - 1 second or 2 presses Hold 1 Sec or
2 Times
To change the selection of any of these features, follow the step by step
programming procedures, and do not allow more then 15 seconds to pass
between any two steps or the system will terminate the programming mode.
There is no need to complete the entire programming sequence. After the
appropriate features have been changed, simply turn the ignition key off to
Immediately turn the ignition key off then back on.
FEATURE 1 LED Flashes 1 Time
1 chirp = Headlights ON During Disarm Horn Chirps either 1 or 2 Times
2 Chirps = Headlights OFF During Disarm
To change the selection, press and release the lock button on the
transmitter, which will be indicated by the appropriate 1 or 2 chirp signal
from the horn. If you do not want to change this feature, simply press and
release the L.E.D. valet switch 2 times to advance to programmable feature
number 2.
FEATURE 2 LED Flashes 2 Times
1 chirp = Headlights ON During Arm Horn Chirps either 1 or 2 Times
2 Chirps = Headlights OFF During Arm
number 3.
FEATURE 3 LED Flashes 3 Times
1 chirp = Ignition controlled door locks ON Horn Chirps either 1 or 2
Times
2 Chirps = Ignition controlled door locks OFF
number 4.
FEATURE 4 LED Flashes 4 Times
1 chirp = Ignition controlled unlock ON Horn Chirps either 1 or 2 Times
2 Chirps = Ignition controlled unlock OFF
To change the selection, press the lock button on the transmitter, which
will be indicated by the appropriate 1 or 2 chirp signal from the horn. If
you do not want to change this feature, simply press and release the L.E.D.
valet switch 2 times to advance to programmable feature number 5.
FEATURE 5 LED Flashes 5 Times
1 chirp = Ignition controlled unlock DRIVER'S DOOR Horn Chirps either 1
or 2 Times
2 Chirps = Ignition controlled unlock ALL DOORS
valet switch 2 times to advance to programmable feature number 6.
FEATURE 6 LED Flashes 6 Times
1 chirp = PASSIVE ARMING (Automatic Arming) Horn Chirps either 1 or 2
Times
2 Chirps = ACTIVE ARMING (Arm by Remote Only)
valet switch 2 times to advance to programmable feature number 7.
FEATURE 7 LED Flashes 7 Times
1 chirp = PASSIVE DOOR LOCKS Horn Chirps either 1 or 2 Times
2 Chirps = ACTIVE DOOR LOCKS
valet switch 2 times to advance to programmable feature number 8.
FEATURE 8 Do not change this feature selection. It should be left in the
factory preset (1 chirp) mode. Press and release the L.E.D. valet switch 2
times to advance to programmable feature 9.
FEATURE 9 LED Flashes 9 Times
1 chirp = Remote Panic / GREEN transmitter button Horn Chirps either 1 or
2 Times
2 Chirps = Remote Panic / LOCK transmitter button
valet switch 2 times to advance to programmable feature number 10.
FEATURE 10 LED Flashes 10 Times
1 chirp = Trunk Release HOLD GREEN BUTTON 1 SECOND Horn Chirps either 1
or 2 Times
2 Chirps = Trunk Release PRESS GREEN BUTTON 2 TIMES
valet switch 2 times to exit the programming mode.
1 - 20 of 33 Posts
