Hey folks, I searched the forums but couldn't really find anything... most people are trying to keep their HiHy RUNNING!
GOAL: TO BUILD AN ELECTRIC BOAT (with engine back up for emergencies) !
I want to create an electric yacht with gas backup. I want to harvest the gas/electric hybrid engine, rear wheel drive and batteries from a smashed/rolled write off Toyota / Lexus / Nissan hybrid SUV. I figure this system will cost similar to replacing a trashed marine diesel.
So I am dumping virtually all the systems needed for a truck ... front wheel drive train/ seats / brakes / traction control / wheels... almost everything!
I intend to add a LOT more batteries to augment the built in batteries. I want the system to run almost entirely on battery power that can be recharged with shore power when docked, or from solar/wind generators on board.
The gas engine should only kick in in an emergency situation when either the boat needs to really move fast to get out of the way of something or if all the batteries are close to depletion.
So this is where I need you techies to help me please! :thumbsup:
Kind of a weird request, but hopefully I can get some wise counsel from you good folks. And I will be glad to post the results of my project when it's done... the worlds longest and wettest Toyota Highlander .
Thanks in advance!
Ric the Brit in ATL
- What is the bare minimum of parts I need to keep from the truck to run the system if all I am interested in is keeping the drive system? ... I want the batteries, the engine system, and the rear drive unit that will feed the propeller.
- Can anyone recommend a parts list / schematic showing all the parts I need to harvest?
- Can anyone tell me what the optimal voltage to run the http://en.wikipedia.org/wiki/Lexus_Hybrid_Drive electric motors? What would be the best way to wire the truck batteries to a bank of lead acid deep cycle batteries? (The Electric boat systems I have seen so far are typically running on a 48V system (8 X 6V golf cart batteries)).
- Will the system typically stay on battery power if there is ample charge available in the battery banks? I don't want the gas engine to kick in except for emergency situations.
- Will the gas engine also make a good generator in a pinch to run other boat systems such as cabin HVAC unit / water purification / etc etc.
- Is there a system to replace the built in Toyota/Nissan computer and run the entire system from a laptop instead to have total control? (perhaps some sort of testing / prototype system)
- Any recommendations on the best way to hook up the drive shaft to a propeller? Does anyone the maximum rotation speed of the drive shaft when the engine is running at full speed.
- Any recommendations about what to keep of the exhaust system and how to route it?
- Last but not least.. what year and model of hybrid would people recommend for such a project? And does anyone want any of the left over parts?
Thanks in advance!
Ric the Brit in ATL
